Range Extender compatible with SBG8300 and G54
  • October 24, 2024
  • 105 views
Does Arris offer a range extender compatible with the SBG 8300 or G54 modem-routers?
Not direct from arris. But pretty much any range extender should work. I’m a fan of triband ones with the dedicated backhaul.
  • 2275 replies
  • October 24, 2024
