sbg8300
  • June 21, 2025
  • 21 views
Trying Trying to activate And App stops at Registering Have already called she
ntel And the unit is active there but I can't get it on my end
Based on your message, Shental appears to be your internet service provider. Could you please confirm your subscribed internet speed plan?
If you're trying to set up the Surfboard Central app, please note that the gateway (modem/router) must first provide an active internet connection. To confirm this, connect a smartphone, TV, or computer directly to the gateway using an Ethernet cable and check if you have internet access.
