SBG8300 connected, internet on wired connection, no internet via wireless
Forum|alt.badge.img+2
SBG8300 connected to LAN, and I get internet with wired connections, but no internet via wireless connections.
Best answer by MrMarkSH
Thanks to those who tried to help.  Well, we can close this one -- unless someone has a fix for my PC.  Now, after some fiddling with settings, my laptop, phones, 2 other PCs all connect OK.  It’s down to just one PC, and that one is about 12 years old, and has recently displayed the Blue Screen Of Death a few times.  Oh, well, time for a replacement!
  • 2292 replies
  • May 25, 2023
Did you try a simple factory reset
  • 6 replies
  • May 25, 2023
Not yet.  Rebooted, powered down, to no avail.  Would my ISP need to re-provision if I reset?
  • 6 replies
  • May 26, 2023
Well, that seems to have worked.  For now.  It seems that if I make any change in the settings (like a channel or rename) the Modem/Router has to be rebooted.
  • 6 replies
  • May 26, 2023
And away it went.  Had connectivity for a few minutes, then it’s off again.  aaaaaaaaaaaaarhg
  • 2292 replies
  • May 26, 2023
How old is the device?
what happens if you change the channel for the wireless when its not working?
  • 6 replies
  • May 28, 2023
  • 6 replies
  • June 20, 2023
PC was about 12.  Changing channel no help.
