SBG8300 fixes for rubber banding and call problems
  • February 12, 2024
  • 6 replies
  • 94 views
Restarting modem, pc does not work, the problem is getting progressively worse, and app does not change settings.
Do you have a screensnip of the cable connections page and event logs?
Is it only on wifi you have issues or is it wired devices as well?
Are you facing slow speed issue on the devices connected to the modem network or internet dropping on the gaming devices alone?
  • February 13, 2024
packet loss or dropping on the pc.
  • February 14, 2024
As you had mentioned there is a packet loss and dropping on the pc, lets check the cable signal levels by clicking the below link for wired internet:
If Wi-Fi is dropping please click the link to change the Wi-Fi channels :
  • February 27, 2024
i tried to send a file of it, screenshot, or pasted edition of the logs but neither would send and now i acccidentally clicked your solution as the response while responding using mobile
also it's both the wired and wireless connection as an update...
  • February 27, 2024
NO worries. We still get replies so you can reply here.
You should be able to attach them
