SBG8300 limiting speed to 60mbps after router mode
  • February 11, 2025
  • 129 views
Today I switched my SBG8300 from the modem & router mode to WAN over ethernet mode - since I switched to fiber internet.
Unfortunately, the SBG8300 appears to be limiting my 1000mbps to 60mbps, both for ethernet and wifi.
I tested running a cat6 cable directly to the fiber modem and I get the full 1000, but when I run it through the SBG8300 I only get 60.  I’ve restarted it several times and ensured all ethernet ports are set to 1000mbps.  Any solutions or settings I’m missing?
  • February 12, 2025
I’m surprised it works at all. Most modem/router combo devices are either a modem/router combo device, or just a modem.
The guide says you need to use port 4 as wan for the sbg8300. Are you doing this?
https://arris.my.salesforce-sites.com/consumers/articles/General_FAQs/SBG8300-Wi-Fi-Router-Mode
  • February 12, 2025
Yes, my fiber modem has a cat6 cable going into port 4 of the SBG8300.  The “WAN Interface Configuration” DOCSIS [Change] is missing from my Arris SURFboard, but the Hardware → Ethernet menu I can select “WAN Over Ethernet” check box, which I checked.
