SBG8300 shows Online and WiFi lights on after Co-axial cable disconnected
  • June 21, 2023
  • 91 views
Hi,
I have an SBG8300.
My internet was down this morning, but the online and Wi-Fi lights were illuminated. I tried in connecting and reconnecting the power. No luck. Then I tried resetting with a paper clip. I held the button down for a minute (timed). Nothing happened. The lights stayed on the whole time. When I disconnect the internet cable (the power cable is the only thing left plugged in), the online and wifi lights are still illuminated. Even if I power cycle, the second I plug the power cable in, it says I have wifi, even without the wifi cable.
I’m at a loss for what to do here. Is there another way to reset my device? Do I just need to buy a new one?
Hello eric28446,
Could you let us know did you try Reset without co-axial cable ?
Also, hardwire the modem and check IPV4 address
For further assistance reach to the link provided below:
arris.com/consumersupport.
  • June 21, 2023
If you disconnect the coax from it, then reset it while its powered on, what happens? (with coax off)
Hello eric28446,
