SGB8300 Online light is Blue flashing and Wi-Fi is Solid Green : Unable to connect
  • May 25, 2023
  • 1970 views
Top light is slow blue flash. Bottom light solid green. Cox says they can not see the modem.
The top slow blinking blue means its trying to connect back to the ISP.
If its not stopping, its not connecting back to the isp.
If none of that helps, the isp might need to check the line
https://arris.my.salesforce-sites.com/consumers/articles/General_FAQs/SBG8300-LED-Light-Status/?l=en_US&fs=RelatedArticle
  • May 25, 2023
