Slow speed internet on sbg8300
  • September 3, 2024
  • 36 views
I got a SBG8300 and I reset it cause it was running slow and now it’s stuck on the blue light and it don’t even let me reset it again. I unplugged it overnight and still the same thing. Any help would be appreciated.
In this case you we would suggest to check for the modem activation and also the connection of coax cable connected to the modem so that will fix the issue. Please do reach out to your service provider for re activation.
