Surfboard 8300 overheating issue
  • July 19, 2023
  • 449 views
My brand new surfboard 8300, runs at ~ 100f . This is on a shelf with nothing around it.  Picked up a small desk fan and that keeps the Modem at 75f or so, but the fan needs to run constantly,
Hi Reklund,
As you had mentioned the modem temperature runs from -100f and 75f with the help of a fan, please check if the modem is hot to the touch (not bearable) then would advise disconnecting the modem and contacting arris by reaching arris.com/consumersupport.
If you have any questions let us know.
  • July 21, 2023
Its not unusual for devices to run around that 100f mark. My RAXE500 runs around that temp but its a little newer and higher powered.
One thing you can check though is the modem signal level. to high of a signal can cause them to run warm.
(a screen snip helps)
And a fan is never a bad idea. I’ve used laptop coolers before on my more expensive routers/gateways to cool them as heat is the death of electronics
Hi Reklund,
