surfboard sbg8300 with surfboard max mesh units
  • February 28, 2026
  • 12 views
i need to extend wifi coverage at home.  budget is limited.  i have an arris surfboard sbg3800 that is my cable modem/wifi router.  hoping i can buy one of the wifi6 mesh units.  i am unable to run any cat6 to other parts of the home so hoping i can extend via just using the mesh units
If you are unable to run an Ethernet cable to connect the main mesh unit, then a mesh system may not be ideal, as the primary mesh unit must be connected via Ethernet.
We recommend using a dual‑pack mesh system. In this setup, the main mesh unit should be connected to the SBG8300, and the second unit can be configured as a wireless satellite that you can place in another area. Please note that both the SBG8300 and the mesh units function as routers. Because of this, you must either:
  • Put the SBG8300 into bridge mode, which disables its router functionality so you can rely entirely on the mesh system, or
  • Configure the mesh units in extender (bridge) mode, which disables their router functionality so they operate solely as extenders.
  • March 2, 2026
How many satellite units can I attach to a W131
You can use up to three units in a single system, one W31 as the main router and two W31 units as satellite
