Unable to connect SONY Television to Wi-Fi
How to add television to my devices.   My television is not listed but other things are.
Hello Grandma1,
Make sure you are able to select the 2.4 GHz Wi-Fi Name on the network settings of Sony Television and type in the Wi-Fi Password .
Let us know if this helps .
  • 2328 replies
  • May 28, 2023
You have to connect the tv to the router. Not the router to the tv.
so you’d want to check with your tv manufacturer how to join a wifi network.
Hello Grandma1,
