Warranty replacement for SBG8300
  • July 25, 2025
  • 31 views
I recently had a power outage do to an animal getting on the power lines. While all my appliances got power, my modem only had the online light on blue solid and no wifi light. I called my ISP thinking it might need to be re provisioned and they couldn't detect the device. I tried resetting it, restarting it, connecting on different ports and nothing.I cant access the gateway via ethernet. I think it might be fried and need a new one if not please let me know what I can do
Try plugging the gateway into a different power outlet, and use an alternate power cord if available.
If the network names still aren’t broadcasting, the next step is to check whether the Ethernet ports are functioning properly.
  1. Click on the Apple menu.
For further assistance, please visit our support channel at www.arris.com/consumersupport.
