arris surfboard svg2482ac router ports and wifi not working
  • December 26, 2024
  • 55 views
I have reset back to factory setting multiple times.  I have no wifi from the surfboard or connection from the ethernet ports to my desktop.  However, I do have connection from the ethernet port to my Google Mesh.  I have been on customer support with Xfinity and they said everything looks ok on their end.  Arris wants me to purchase a service contract of $40 to fix it.  I might as well just buy a new one at that price.  Any ideas?
  • 2328 replies
  • December 27, 2024
did you try factory resetting it?
  • December 27, 2024
Yes.  Several times.
  • 2328 replies
  • December 27, 2024
Seems like its in modem only/bridge mode.
Are you able to log into it and check it?
why do you want its wifi enabled if you’re using the google mesh? That’ll just put you in a double nat
