changing Wi-Fi credentials for SVG2482AC
  • December 6, 2023
  • 204 views
Hello,
Can you please let me know how to change the wifi username for
SVG2482AC ?
When I go to EDIT mode I do not see any option to edit any details , please advise .
If you don't find the option to edit the WIFI credentials even after following all the steps you can try restarting modem for a minute then Please follow the steps mentioned on the below article to change the WIFI credentials on the modem interface.
http://arris.force.com/consumers/articles/General_FAQs/SVG2482AC-Changing-the-Wi-Fi-Name-and-Password
Thanks for your response !
Here the problem is that the Edit option does not let me change anything , basically all the fields are non -editable even when I click on EDIT .
I even tried doing a Factory reset but as soon as I configure network name & Password either for 2.4 or 5 GHz the other wifi disappears .
So due to this issue I am unable to make use of both the WIfi .
Please advise .
Thanks!
Since the Wi-Fi network name is disappears, could you let us know the firmware version.
Also I suggest you to factory reset the modem and try to login the GUI portal without co-axial cable and customize the Wi-Fi credentials.
