Firmware update on SVG2482AC
  • April 10, 2024
  • 1193 views
I've been tryin to update my firmware on svg2482ac  but I can't find it
 The Cable Operators (MSOs) have complete control of what cable modem/gateway hardware they will allow installed and the firmware it uses, this is because they own the coaxial cable that is connected to the ARRIS (SVG2482), because of that the Firmware updates are pushed by them, and any update needed as well. Any associated firmware updates are automatically deployed by the cable operator. This is not an ARRIS only implementation, but the required implementation of any cable device manufacturer.
Even for the device owned by the customers only ISP can send updated to the modem since the device getting signal from the internet service provider (ISP)
