how to connect to 2.4 GHz on SVG2482-AC
  • May 19, 2025
  • 75 views
Need to connect to 2.4 GHz to activate security camera
Could you check whether two different Wi-Fi network names appear on your devices?
If you're unable to locate both networks, I recommend logging into the web GUI portal to customize your Wi-Fi credentials.
Please follow the instructions provided in the link below:
http://arris.force.com/consumers/articles/knowledge/SVG2482AC-Changing-the-Wi-Fi-Name-and-Password
Could you help us with the product’s model number to assist you further?
  • May 19, 2025
Model SVG2482AC
