http://10.0.0.1 won't open
  • December 2, 2025
  • 34 views
Tried 3 different browsers. All time out. Issue is with getting new TV to access Wi-Fi Network through SVG2482AC. It worked fine on old TV. Old password apparently forgotten. Would like to try resetting password
If you have forgotten your Wi-Fi password, you can retrieve it from an existing device, such as a mobile phone or computer, that is already connected to the Wi-Fi network. Simply go into the device’s settings to view the saved password.
Additionally, whenever you try to access the gateway’s interface page, make sure you are connected to its network. The interface page will only appear when you are on the gateway’s network.
