intemittent internet connection on SVG2482AC
  • December 9, 2023
  • 205 views
I getting am  frequent connection drops on my internet connection.  Comcast says everything looks fine.  They say it  could be my owned Arris modem.  Of course they would say that.
Is there a tool / software that I can run to show what the router is seeing?  Is there some home version of “Sniffer”.
Since you are experiencing with intermittent internet connection, let us know whether the issue is with wired connection or wireless connection.
If its wired intermittent internet connection, I suggest you to check the cable signal levels.
To check the same, find the steps in the below given link:
http://arris.force.com/consumers/articles/General_FAQs/SVG2482AC-Cable-Signal-Levels
If you are experiencing wireless intermittent connection, change the Wi-Fi channels by following the given link.
http://arris.force.com/consumers/articles/General_FAQs/SVG2482AC-Changing-the-Wireless-Channel
  • December 11, 2023
Im having the same issue with same model and xfinity. When tech was st my house we were hitting faster 400Mbps speeds, but by end of the day, speeds again dropped to 25Mbps.
Xfinity says its my modem as well. it is 4 months old. Im wondering if there was a firmware update released and either xfinity ddnt test it or has not applied it.
I cant find where the latest firmware should be.
