Surfboard SVG2482AC not being seen by Tivo Bolt connected directly by Ethernet cable
  • February 20, 2023
  • 47 views
New SVG 2482AC connected with Ethernet cable
Tivo Bolt uses Cablecard from Comcast/Xfinity
connection to old router only stopped recently.
Old router  is the exact same model as the new router
This is the model recommended by Xfinity/ Comcast
The WiFi on this new router works fine
After activating the new router one of the TV’s on the network ( which uses a TIVO Mini ) connected to the network through the TiVo Bolt and I was able to watch Live TV. Within five minutes of watching the live tv the connection was lost. When I tried to reconnect to the network I recieved the error message ROUTER NOT FOUND. And there or code was (C107)
Hello Dagriz,
We understand that you are facing error code “C107” on Tivo Mini/Bolt. Would recommend to do a Power cycle (unplug and plug back the power cord) on the Tivo Mini/Bolt and try again to connect .
If still you are facing the error please contact the manufacturer. of Tivo Mini/Bolt.
Hope this information will be helpful.
