SVG2482AC battery backup not working during blackout
  • December 14, 2024
  • 13 replies
  • 142 views
JBlue
The Certified
Forum|alt.badge.img+3
My SVG2482AC battery backup is not working during blackout; when the power comes back the battery light on the modem is illuminated; when the power is out the battery light was off. Any help appreciated.
pretty easy to test. Wait for the battery to charge and unplug it and see if it stays on. If it doesn’t, probably the battery.
You might have only bought it 2 years ago but it was released in 2017. theoretically, it could have sat on a shelf that long somewhere and could be sketchy at best.
  • December 16, 2024
how old is the device’s battery?
It was released in 2017 so the battery itself might be bad and need replacing (not sure if I’d invest any $ in that old modem/router).
JBlue
The Certified
  • December 16, 2024
thanks for the response, it’s less than 2 years old; I noticed the battery light was not on previously, maybe the connection was not tight, it’s on now; I guess I’ll find out if it works during the next blackout;
what is the the newer model of this modem? I bought the SVG2482AC for the landline phone jack…..
  • December 16, 2024
JBlue
The Certified
  • December 16, 2024
I unplugged it and it failed. is the modem supposed to transparently cutover to battery power if the battery is good? Or is there some other reboot required?
  • December 16, 2024
pulling the plug should simulate loosing power. It should switch over as far as I’m aware. I don’t have that device so can’t comment on that 100% but thats the goal of a battery backup
JBlue
The Certified
  • December 16, 2024
I contacted the vendor, it’s not refundable. They’re original batteries, as you say, perhaps from 2017, I bought mine early 2023.  It was probably a dud when I bought it. I didn’t think to check it at the time. Lesson learned.
  • December 17, 2024
You can replace them. But not sure if I'd invest in a router that old
JBlue
The Certified
  • December 17, 2024
thanks for the responses. what router would you recommend? I need telephone, hi-speed capable, xfinity compatible, with battery backup, thanks,
  • December 17, 2024
Battery backup makes it hard. What I'd do? Pickup a UPS (backup power supply). Use it with the current one and when you need to upgrade, because if the UPS, you have more options because you just need a router that does telephone
JBlue
The Certified
  • December 17, 2024
good idea, I’ll check  it out, thanks for your help.
  • December 17, 2024
Nice thing is that since its just a router/modem, it doesn’t take much power from a backup power supply. I’ve got a APC brand 425VA that backs up my modem/router/switches and have been rock solid.
JBlue
The Certified
  • December 17, 2024
Thank you.  I’m not familiar with UPS other than surge protection.  How long can I expect the APC 425V to provide power to the SVG2482AC in a black out event?
  • December 17, 2024
Easily over 30 minutes if its just the modem/router
