SVG2482AC GUI login issue.
  • February 6, 2026
  • 72 views
Existing password to login was not validated. Tried “password”. Invalid. Did 3 factory resets. Unresolved. Tried S/N last 8 digits. Invalid. I can see from initial screen that modem was factory reset. however it will not validate passwords. How to flash whatever is stuck in this modem?
For the SVG2482AC, if logging into the interface with the default credentials doesn’t work, try using the default Wi-Fi credentials instead.
  • February 12, 2026
Do you mean to enter SSID instead of login and network key instead of password even when i am not using wifi interface?
  • February 12, 2026
amazing.. i used admin and wifi password and it validated it. thanks
  • February 12, 2026
unbelievable.. so I successfully logged in with wifi password. Went to setting to change default password. i saved it. Now it will not validate neither new password nor default.
