wifi extender not arris
  • July 19, 2023
  • 85 views
Hello, I was wondering if it possible to use an Netgear AX1800 EAX14 with an Arris SVG2482AC? Is it possible to connect both together with Ethernet. If not what would anyone suggest to use.
Hi Link007,
Since you are planning to connect Netgear AX1800 EAX14 with Arris SVG2482AC with Ethernet yes, it is possible to do it.
Basically, Netgear AX1800  EAX14 is a Wi-Fi 6  Mesh extender that can be connected through an ethernet port (which is located at the side /back of the extender) and also to a  Wi-Fi network.
Let us know if this helps.
Hi Link007,
