192.168.0.1 uses an unsupported protocol
  • January 13, 2024
  • 172 views
SBG6900. Need solution for problem above.
Best answer by skip
Thanks for the response but someone said to open the page in Internet Explorer and voila! Don’t know why but it worked.
  • January 13, 2024
a bit more details on where/why you’re getting this. You’re description is a bit brief.
  • January 14, 2024
