BGW210-700 Configuration Manual
  • January 17, 2024
  • 200 views
I have a BGW210-700 DSL modem provided by AT&T.
I need to configure the unit to port forward messages directed to the unit from the internet to an IP on my Lan. The modem has a static IP.
What I would really like is a configuration manual on the device.
BGW210-700 is not supported by Arris.  Arris supports only the retail products that are available on surfboard.com but not the ISP lease products.
Probably check with your ISP for further information.
