changing password for network - SBG6580-2
  • October 21, 2023
  • 260 views
I have a modem and have not used it for years. I do not have the password. How do I change the password without knowing the current one?
factory reset it back to stock. then the install guide should work
  • October 21, 2023
  • October 28, 2023
I found the hole to reset the device on the back. Thank you, it was easy.
