Internet no connection sbg6580
  • November 7, 2022
  • 214 views
Sbg6580 powers on but then the receive light just keeps flashing. I get a message that says “connected but no internet'
do you have a screensnip of the cable connections page and event logs?
  • 2275 replies
  • November 8, 2022
  • November 10, 2022
Thanks for the input. I had Spectrum come out and there was a whole bunch of problems. The main one was the cable for wifi had been weathered and it finally broke out at the roadside pole. I still have some problems with Spectrum.
