Modem and Router recommendation
  • November 26, 2024
  • 38 views
Hi Folks,
Our current ISP provider is Xfinity (2000Mbps service) and we are presently using their Modem/Router. We are considering replacing their unit by procuring one of our own modem and router in order to reduce our monthly bills. Consequently, we are using this medium to ascertain your assistance on what modem you would recommend as suitable for our application. Kindly note that we are interested in separate units i.e modem/router and which are wifi7 compatible.
Since you are preferring the wifi cable modem which is compatible with WIFI 7, I would suggest the model G54.
  • November 27, 2024
Thanks for the timely response and recommendation, it is greatly appreciated.
  • November 27, 2024
the G36 also meets your needs. Here’s the full list from all the manufacturers. If you’ve got the 2 gig service, make sure to get a multigig device.
https://assets.xfinity.com/assets/dotcom/projects/cix-4997_compatible-devices/2024.09.18%20Full%20List%20of%20Compatible%20Devices.pdf
  • November 27, 2024
Hi Plemans,
Thanks for the advice/info it is greatly appreciated. Have a good day.
  • November 27, 2024
good luck! black friday is a great time to get a new modem/router. I prefer the modem separate from the router so your firmware isn’t locked and if one device goes bad, you’re not out both of them.
