No wifi internet on
  • November 27, 2024
  • 78 views
Model:SBG7580-AC
Connected wifi wire from another modem to use this device as a router. Met a problem that if I connect my device wired internet is working, but if I connect my device via wireless connection it's getting connected without ethernet connection.
So you’re trying to use a modem/router combo device as a router only device?
I know there’s a bridge modem that disables the router side but not if there’s a vice versa.
https://arris.my.salesforce-sites.com/consumers/articles/General_FAQs/SBG7580-AC-Bridge-Mode-Setup
  • November 28, 2024
