Router WiFi with Matter firmware
I would like to know if you have any router wifi with Matter compatibility (Matter 1.0 or 1.1,  the standard for the IoT home connectivity).
I looked through internet and I saw that you (Arris) provides routers to Comcast with WiFi 6 and with Matter. Does it have the matter controller installed? Where can I buy it?
https://corporate.comcast.com/press/releases/comcast-wifi-6e-fastest-router-gateway-10G-low-latency
Thank you. Regards.
Hello Irene,
Well we don't have routers that support WiFi 6 with Matter compatibility . For more information,  do check for any updation by visiting shop.surfboard.com
Let us know if this helps .
Hello Irene,
  • June 26, 2023
Ok. Thank you.
As I have understood you don’t have the router with Matter compatibility available. But the announce about xFi Advanced Gateway (on the web below) that says that it has Matter, it only belongs to the Comcast offer (to their customers) related with your hardware.
I would appreciate your clarification to this point if it is possible, to know if I have understood correctly.
Thank you, best regards.
