SBG6580-2 : LED LIGHT STATUS: RECEIVE / LIGHT IS BLINKING : No internet
  • April 29, 2023
  • 555 views
Yesterday my SBG6580-2 receive light started blinking and wifi stopped working. I have tried power cycling and the hard reset button on the machine. Looking at different trouble shooting didn't help since there wasn't a case written out with the same light combination. What are the next steps I should pursue? When do I say this machine is broken and get another one?
Lights
Power light is on solid and green
The receive light is on, green, and blinking
The send light is off
The wifi is on, green, and flickers on/off
Hello Gwines,
As you had mentioned the light status of Power/Receive / Send and WiFi , could you let us know the light status of Online (4th light) so it will be easy to understand the issue .
Hello Gwines,
