SBG6580 connection dropping. Low upstream power?
 My SBG6580 modem starts fine, establishes a connection, and appears to work normally. But will drop after a while and, and attempt reconnect. This happens between several times an hour, and a day+
(edit: CM-MAC information removed)
Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6
Time Not Established Notice (6) WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INIT
Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0;
Hello Ranolden,
It looks like an intermittent connection, looking at the cable signal levels the downstream Power levels lowest  6.4 and highest 6.9 dbmv which is on acceptable range (+15/-15 dbmv ) and SNR lowest 38.2 and highest 38.6 db which is in acceptable range (+33 db) , but looking at upstream channels  the power levels should be 45+ to 52+ dbmv but it is only lowest 33.3 and highest 35.5 dbmv which is very low and not in acceptable range .
Do contact your ISP and try increasing the values to 45+ to 52+ dbmv.
After increasing the Upstream values , lets change the WiFi channels : follow the link below:
http://arris.force.com/consumers/articles/General_FAQs/SBG6580-v8-5-x-Changing-the-Wireless-Channel
Do let us know if this helps.
Hello Ranolden,
  • July 1, 2023
SURFboard Moderator wrote:
Hello Ranolden,
Is this something they can change remotely? They are saying I need to schedule a technician to come out here
