SBG6700
  • December 21, 2022
  • 251 views
I’ve been searching for a fix for this for hours and nothing works and nothing I’m finding is helping. Every time I try and access the admin site I get this error no matter the browser I use. I’ve factory reset the router, I’ve unplugged and replugged multiple times. I’m at a loss.
Secure Connection Failed
An error occurred during a connection to 192.168.0.1. Peer using unsupported version of security protocol.
Error code: SSL_ERROR_UNSUPPORTED_VERSION
    The page you are trying to view cannot be shown because the authenticity of the received data could not be verified.
    Please contact the website owners to inform them of this problem.
This website might not support the TLS 1.2 protocol, which is the minimum version supported by Firefox.
Learn more…
Best answer by Anonymous
Another member resolved the same issue from this thread.  Give it a try.
  • December 22, 2022
  • December 22, 2022
That worked 110% Thank you, thank you, thank you.
