So, I’ve had this Arris SBG7580-AC modem for years which was prior to the rollout and implementation of the McAfee Security firmware on this model. However, Comcast pushed an firmware update to my modem which I felt was an intrusion. Making a long story short working with Arris Executive Customer Support, Comcast and McAfee engineer’s all of the technical support persons did not know how to disable this McAfee Firmware. Eventually, working together they came up with some coding to disable the functionality. Just wanted to mention this.
Now, moving forward many years I know this modem is discontinued. Not being technically knowledgeable enough, I’m wanting to know if this modem has the capability to support Xfinity’s higher speeds? I don’t know if the higher speeds which are available for Wifi 6Ghz range.
Thanks for the response and knowledge.
