SVG2482VC - WIFI Devices
  • April 27, 2023
  • 228 views
Is there anyway to REMOVE a device from my connected list (IE: DELETE it from my ACTIVE list)
Without BLOCKING the device or RESETTING my entire router. My problem is that i need to REMOVE my device entirely from being associated with my router, to allow me to reconnect it to my network. But it seems this router can only REMOVE a device by placing it on a block list?
HELP PLEASE!
Hello DrSmith79
                             For SVG2482AC and for all Arris modem you will be having option only to block the device so that it will be get deactivated from the modem wifi and if you want to remove the device completely from the modem settings completely then the only option is to reset modem and customizing the network then connect to the new wifi on your devices.
Hello DrSmith79
