Unable to Access Network Router at 192.168.0.1: Wi-Fi Connectivity Issues
  • August 28, 2024
  • 94 views
Hi everyone,
I’m facing issues to  access my network router's settings at 192.168.0.1. My Wi-Fi connection is stable, but I can’t reach the router’s admin page to make configuration changes. I’ve tried different browsers and cleared the cache, but the page still won’t load. I’ve also checked that the router is correctly connected and powered on. give me suggestions to solve my issuse .Thank you.
In this case we would suggest you to try on different browsers or using different devices or try on direct connection if still not accessible try the same after disconnecting coax cable from the modem. To check on this more could you please help us with your modem model number.
