Unable to connect Wi-Fi on SBG6700-AC
  • June 19, 2024
  • 37 views
unable to connect to wi fi with my SBG6700-AC
Could you please help us with the LED light status on the modem to help you on this further. Also have you customized the default wifi credentials mentioned on the modem label or you are still using the default wifi name to connect your devices to the modem wifi network?
