I have the model DG3450 i guess (it says it on the bottom), it only has two status lights (Online and Wifi) which are supposed to be green. I came home from work 3 days ago and noticed that their now light blue and have been like this since. I’ve tried unplugging and resetting but whenever it comes back on it just goes back blue and doesn’t do anything else. I’m not sure what to do?
Wifi not working anymore? DG3450
Hi User9292,
Well, could you let us know did you check with Arris Technical Support or your Internet Service Provider? If it would have been Arris Technical Support we don't support DG3450 and hence we guide you to check with your ISP(Internet Service Provider) for further support.
For more details please follow the below link for DG3450:
https://www.commscope.com/globalassets/digizuite/62380-touchstone-dg3450-data-sheet.pdf
Hope this helps.
