Wifi turned off
  • December 12, 2022
  • 154 views
I’m using an NVG578LX router with the wifi turned off. The wifi indicator light on the front of the unit is off/dark.
Does this turn off emf coming from the router or just the intelligence (modulation) of the emf?
Thank You for a reply
Bill K
Hello BoxcarBill
I would like to inform you that NVG578LX is not supported by ARRIS directly. However, I can help you with the information. Usually powering off the Wi-Fi in Router/Gateway will reduce the exposure to EMF.
Let us know if this helps.
Hello BoxcarBill
  • December 21, 2022
Yes, thank you, I assumed the unit wasn’t emitting emf due to the fact the heat coming from the top vent has been greatly reduced since I turned off the 2.4 & 5g “wifi”.
