remote access/management for TG2482 Cable Voice Gateway
  • November 28, 2023
  • 206 views
Hi, I have received the TG2482 from my internet provider.
In the spec sheet it says: remote WebGUI access.
How can I access this router remotely from WAN?
I have not been able to find anything in the manual or on the locally accessed web interface.
Hopefully somebody can help.
Thank you in advance.
TG2482 is a not supported device. Arris supports only the retail products that are available on surfboard.com but not the ISP lease products. Just to provide you the general information on this you can access modem interface by searching for modem IP 10.0.0.1 on any web browser connected to home network and enter the login credentials username: admin and password: password in lowercase if this doesn't allow you to login to interface you need to reach out to your Internet service provider only.
  • December 10, 2023
Thank you for your reply.
