Answer
canon mg6821 will not connect to g36 via wifi
  • November 22, 2024
  • 73 views
I just got off cable and have internet thru Xfinity. My printer connected fine to Wi-Fi before. Now I have this new combination modem and router and it won’t connect.   I have another printer in another room that connected fine. That was an HP printer.
Could you let me know which wifi network you are trying to connect with the printer?
I would suggest connecting to a 2.4G network. If the same problem persists, change the security mode and try again to connect the printer.
Launch a web browser and enter in the address box as 192.168.0.1. Login with your credentials
Gateway>Summary>Connection>Wifi>Networks> Edit 2.4G network as WPAWPA2-PSK (TKIP/AES)
  • November 22, 2024
What error does it give you?
Make sure to use wpa2/wpa3 mixed mode on the g36. Non wpa3 devices need the wpa2 connection
General FAQs: G34/G36: Unable to Connect to the Wi-Fi Network
  • November 22, 2024
Thanks for responding.  The modem is showing up in my printer but it just keeps saying it failed to connect to the wireless router.
thanks again
