G34 Access for Speed Test
  • January 6, 2023
  • 8 replies
  • 305 views
When I attempt to run a speed test from my iPhone on my surfboard G34 I get the error, “ access to your network is currently unavailable” How do I get access to network?
Looks like its not currently working according to the mod’s.
  • January 9, 2023
Good question! I have the same problem when I try to use Central. Even though I am already on the network.The app is a big Fail, IMHO. So many things Arris should have fixed in Beta before rolling out the worthless app.
  • January 16, 2023
Does anyone have a solution to my connectivity issue so I can run a speed test?
  • January 16, 2023
Have you simple tried using the speedtest app?
Or having a hardwired in pc/laptop and testing the speeds that route?
I’m not a huge fan of built in speedtests as they aren’t always accurate
  • January 16, 2023
Yes, the picture I sent is of the app. Im wanting to test iPhone to modem to internet speeds, so I didn’t use a laptop. I ran this test before when I first purchased the modem so I know it possible to use this configuration.
  • January 16, 2023
  • January 16, 2023
This issue isn’t the modem, the modem and router are operating fine. The issue is I get the message that access to the network as unavailable. How do I get access to them at work?
  • January 20, 2023
Can anyone help with this issue?
  • January 20, 2023
Did you click on the link I posted? it says its not currently working and is posted by a moderator.
Update: Speed Test Service | Community (surfboard.com)
This link
