G34 Upload Speed
  • October 20, 2022
  • 117 views
What is the upload speed of the G34?
Its more about what your ISP supports. The upload side of modems has always been held back by the ISP. For example, my 1.2gig download connection only has a 35mbps upload. But thats set by the ISP. They can increase that as I’ve only got 4x of my 8x channels locked. It isn’t usually the modem that’s holding back the upload speeds.
  • 2277 replies
  • October 21, 2022
