G36 Ethernet to tv
  • February 11, 2024
  • 131 views
I just did a hard connection to my TV with an Ethernet cable and all I get is an amber blinking light
Amber blinking on ethernet port is very normal behavior. It Indicates data traffic is in progress.
Do you see the blinking Amber light on the ethernet port or on the modem front panel?
  • February 12, 2024
In back of the modem where the cable is plugged into the port
  • February 12, 2024
WHEW 😅
Thanks 🙏
