g36 modem/router xfinity intermittent connection
  • January 16, 2025
  • 9 replies
  • 127 views
I had xfinity out a few weeks ago to address intermittent internet connectivity. The same issue seems to be happening again since yesterday.
Xfinity tech spent about 2 hours getting the updates to go through and I had hopes to be in the clear. Is there another update that is stuck?
I would like to not have to replace this as I spent the extra money and it is supposed to be compatible with xfinity. My last modem and router set lasted me 8+ years. I think this Arris g36 is in year 2 and according to the site my warranty has expired…
  • 2252 replies
  • January 16, 2025
The first rep xfinity sends out is usually only rated to check the connection from the hub to the home. It doesn’t always fix the issue and sometimes they have to bump it up.
do you have a copy of the cable connections page and event logs? (screensnip them please)
  • January 16, 2025
Not sure what cable connections page is. Is that something from xfinity?
  • January 16, 2025
Also, curious what’s the issue that you’re referring to?
  • 2252 replies
  • January 17, 2025
Issue= the problem you’re having
Cable connections page shows your cable modem data with upstream/downstream values that show the current connections (not past). Which is why that info plus the event logs helps as that shows longer term
  • January 17, 2025
How would I access this “Cable connections page”? from Xfinity?
  • 2252 replies
  • January 18, 2025
Could you please specify whether the intermittent connection is happening on the Wi-Fi or the wired connection?
When the internet connection drops, does the gateway (G36) reboots on its own?
I am having similar issue since past 1 week and using G36. Can someone help to fix?
its working for sometime once I restart modem and issue starts showing again
  • 2252 replies
  • January 20, 2025
@vaibhav.rupapara Pleases start your own thread/post so your info isn’t confused with the OP’s information. Your line looks like it has issues but you’ve only shown part of the data.
