Arris G54 DTIM Settings
  • June 1, 2024
  • 8 replies
  • 188 views
So I’m at a loss….. I’m trying to locate the DTMI settings on the admin page for the Arris G54. But I’m not finding them anywhere. Am I just completely overlooking it?!
thanks
I regret to inform you that the DTIM settings are not available on the Arris modem/gateway.
Sorry. DTIM settings.
Is there a plan to enable this and is there a place to see what the current default value is?
There is no option to check the current default value for DTIM.
What is the factory default DTIM setting - I need it to control an MCU sleep cycle.
There is no option to check the default settings for DTIM.
I’m sorry for the confusion: I don’t want to check it I want you to tell me what it is.  It is set in the firmware by the modem manufacturer.  Please ask them what it is and tell me.
Thanks
DTIM is a networking term that stands for delivery traffic indication message. That helps to know the packets of information that are broadcast through a network.
Regarding any information about firmware, I would suggest contacting the ISP for further assistance.
