Does the mAX use band steering?
Best answer by dan_w
View originalYes, the SURFboard mAX supports band steering. It can be enabled using the SURFboard Central mobile app. Click on Network towards the bottom of the screen, then select Extended Wi-Fi Settings to enable the feature.
