Installing a switch with SurfBoard mesh system W121/W21
  • 12 April 2023
  • 213 views
We have a SurfBoard SB8200 feeding two SurfBoard Max 6600 Mesh routers.
We have several devices that need to be connected using ethernet. Since there’s only one port on the mesh routers I got a switch. This is proving to be problematic at best. One of the devices isn’t even showing up on the network.
Is there some sort of trick to this?
TIA
Userlevel 6
Badge +40
What actual mesh router did you get?
Also, keep in mind that even though the SB8200 has 2x ethernet ports, the vast majority of ISP’s only support 1 device connected. Reason why is the ISP assigns a public ip address and they only assign 1.
So it needs to go modem---->router--->switch/satellites.
W121 two-pack.
Right now I’ve got it set up like:
SurfBoard8200 (Modem) ->W121#1->switch->W121#2 and other devices
Userlevel 6
Badge +40
W121 two-pack.
That seems like how you should have it.
Userlevel 3
Badge +23
W121 two-pack.
Is the switch connected to W121 #1 or #2?
SurfBoard8200 (Modem) ->W121#1-> 5GHz Backhaul >W121#2 (switch > wired devices)
SurfBoard8200 (Modem) ->W121#1 (switch > wired devices) > 5GHz Backhaul >W121#2
If the wired devices connected to switch is not showing up in the app, I would think the switch is managing those wired devices.  If it’s unmanaged switch, the wired devices should show up in the app.
I suggest removing the switch and connect a wired device to the W121 to see if it shows up in the app.  Go to My Network, select main or satellite, and check the Ethernet connection.
