Part of the 2022 W121 Beta program it ran really well until the App update early in the year, since then I have no access as the downloaded update stalls at the setup screen, My contact is now unresponsive and after a recent power cut I dont know how I got them back on but I did, my worry is going forward if this happens again and I cant get them back up I will be a bit stuck.
I sign into the App and get to “Set up you home network” and it just spins, I would try a factory reset but my concern is help to get back online if that fails, I cant even tell you what version it is ?
It was all going so well ………………..
