What can I use with DSL service?
I have DSL service, can I use a mAX system?
Best answer by dan_w
If your DSL service does not require you to login using a username and password, then the mAX system will work with your DSL service.  If your DSL service is still using older technology known as PPPoE which requires you to login using a username and password, then the mAX system is not compatible with your service.
  • Button Mashers
  • 9 replies
  • May 27, 2022
  • 2275 replies
  • July 13, 2022
I frequently seen users use their provided dsl modem/router from their isp. They then connect their max system to that router. You can either put the max systems ip address into the dls routers DMZ or put the max in access point mode.
