adding extra satellites
  • September 15, 2023
  • 671 views
I need to add more than 3 satellites to my system.
however, the app won’t let me do that.    Is there a way to work around this?
current system consists of a modem (sb8200) wired to w31.  This is then wired to a w30 and this is then wired to another w30.    By “wired”, I mean connected via Ethernet.     The distance is rather long between the satellites and my home is old with lots of interference in the walls.     I have a 4th satellite that I want to add but can’t figure out how.
what about upgrading the modem to a wifi capable one and then moving the satellite that is currently connected to it, to a different location?    I still think I will need 4 satellites…
any thoughts?
Best answer by LoveMyLab
I’m not familiar with the W31 but after reviewing the specs it appears you are going to have a challenge doing what you want. It looks like only 2 satellites are supported and they must be wired directly to the primary. So, the max capability is 3 units and no “daisy chaining”.
Some other folks support daisy chaining, but hub and spoke is usually a little superior. In my case, I use Google, and place a set of D-link unmanaged switches after the router designated as primary. My 4 satellites are using ethenet backhaul to the switches. It sounds like you and I have similar challenges to overcome.  I’m running 5 units due to challenges with concrete and steel in certain locations.
You’ll probably have to go through the Arris product catalog and see if they have a different primary that enables what you want. I would keep the modem and primary router as separate units. If I had to replace my system today, I’d use the Google Nest WiFi Pro units, but that’s just me.
https://arris.my.salesforce-sites.com/consumers/articles/General_FAQs/mAX-W30-W31-Add-Additional-mAX-Satellite#:~:text=A%20Satellite%20can%20be%20added,successfully%20over%20Wi%2DFi%20connection.
LoveMyLab
Guardians of the Gateways
Forum|alt.badge.img+19
  • Guardians of the Gateways
